whos got the nicest
Christ this is a tough one..........
There's loads
Nicest as in looking??
B19 TRB i especially like,butch's for power.
There's so many,so hard to pick one
Rich
There's loads
Rich
well - i would have to say mine ....................
but if i wanted the next best all round rst - it would be B19 TRB.......
There are some nice one's about, hard to say really...... All have good qualitys about em. I personally like the more standard look, but it must be full 90 spec
theres definetly some nice ones about... id say bodge's or pauls for the S2 and matt sabs for the S1, thou im not keen on his stickers he's put on!
nice to see i get a mention thou! I think id stand a chance of wining the most moddified!
Have to agree on Matt's S1, although I saw a cracking example down safff end @ last weeks PF meet! 300 odd BHP with full blown antilag! what a monster!
Also, I like Chewy's and DOO's old S2 Very nice indeeed!
too hard to say, theres fucking loads of mint RST's on here , although if i've got to pick one, i'd say mine
mark4, chewy's, bodge's etc etc. all nice as fcuk. they're all red too infact
& whats mine a 1.1 nova engine in it!
u want power u want B19 TRB
My car does look the bollox though!
lamar whats your spec then?? power ???
mine there more as this is an old spec now lol
P.E systems two 1905 engine
Balanced 88mm cast iron allow crank
Forged rods
Hi-duty big end and main bearings
fully floating bronze small ends
83mm German Mahle pistons
Goetze piston rings
high flow oil pump
Stage three head gas-flowed with bigger inlet and exhaust valves, valve seats opened up and cut to tree angles and enlarged reshaped ports, bronze guides
power+ camshaft SX428T
Alloy vernier pulley kent
Gear box uprated
4 paddle clutch NEW
Lightened flywheel
5th injector which comes in at 12psi
Hybrid turbo 3.5 all singing and danceing
collins actuator same as -31
boost set about 19psi - 20psi which is a turbo systems chip
Mongoose stainless exhaust with modded down pipe with lamba fitted
K@N cone filter
large capacity GSR intercooler
Samco silicon boost hoses
Samco silicon water hoses
Group A dump valve in cross pipe (taken off now)
Front brakes 4-pot wilwood DL calipers 305mm x-drilled discs
EBC green stuff pads
Braided hoses
Rear 4wd cozzy calipers with 280mm x-drilled discs
Braided hoses
Koni adjustable shocks on each corner
lowered springs 30mm
Full poly bushes
17" silauto alloys with 205/40/17 yoko tyres
Auto meter boost gauge
A pillar pod
Momo race steering wheel and gear nob
costom twin pod for AFM and ACT gauges
Auto meter Air to Fuel gauge drilled in to exhaust lamba
shiney bits
spec-r cam belt cover
spec-r conical filter heatshield
spec-r fuse cover
spec-r slam panel blanks
stainless wiper back plate
stainless wiper cover
stainless throttle cable cover
stainless suspension tops
stainless turbo heatshield
stainless under bonnet panel
stainless servo cover
alloy strut brace
polished coil
polished fuel filter
polished stat housing
chrome rocker cover
chrome engine lifting eyes
chrome bonnet catch
chrome cross pipe
chrome 5th injector mount
chrome bonnet hinges
forge motorsport polished header tank
polished alloy header cap
polished inlet manifold
stainless oval cap for washer tank
stainless battery cover
stainless brake fluid cover and cap
Bailey oil separator polished alloy
last power run made 240bhp and 253lbs with bad boost drop and MF2 driver fecked so should be better next time
mark
Forged rods
Goetze piston rings
high flow oil pump
Gear box uprated
4 paddle clutch NEW
Lightened flywheel
K@N cone filter
Braided hoses
Braided hoses
Full poly bushes
A pillar pod
shiney bits
spec-r fuse cover
alloy strut brace
polished coil
chrome rocker cover
chrome bonnet catch
chrome cross pipe
mark
Bodge... my spec is still under progress but roughly its low comp 1600cvh, stage 3 big valve powers/karl norris ported and polished head, powers camshaft SX428T, double valve spring, anti pump lifters, hybrid turbo 48 exhaust housing 55 trim wheel, pace large front mount intercooler, MF2 Aquamist fifth injector running a green injector, running 20psi currently but does need a good setup, hoping to run around 25psi when its setup and should see 250bhp with a bit of luck, it was running 220bhp on the old setup but that was running a stage 2 spec turbo and only 18psi!
still to come is water injection, Nitrous Oxide, oil cooler, and some big brakes.... also gona change the konis for some AVO coilovers. More expense eh! its gettin there thou... should be resprayed again before the shows this year as the bumpers a bit nasty, and the front end has some stone chips, then it will be finished...
I look forward to seeing all the ERST's at the shows this year... I might even enter mine this year, dont think it'l win but worth a try!
good luck m8 i would like to repaint mine you know the small stone chips and stuff but keep getting told i'd be mad if i do lol dont realy want to spend any more now saving for the focus cozzy if it every comes and if the wife lets me
mark
mark
danny h's old s2
I think at the end of the day it is down to personal preference, I know I prefer a full 90 spec S2 with standardish looks, not gay spoilers or shitty tinted windows or lowered to fuck! apmsl!
Must say there are sum loooooovely S2's on here
Originally Posted by B19-TRB
nope!
I thought about it!
but just couldnt!
she should b @ central day!
I thought about it!
but just couldnt!
cant make central day mate, (off to donny ) be there for the next meet tho
bodge and lamar...how much you two spent on your cars!...or dont u wanna go back over it cus you will realise just how much it has been!
ive spent now just over Ł3k and thats getting it ok!..not even great yet!
only mods have been pace interwarmer (fitted today along side new engine)
and st170 brakes reat has been getting it good enough to mod
and now i gotta get it painted ....dam pheasent and vandels!
the most mines cost me is the shiny bit most of the other bits came from my last S2 which i swopped everything over had this one 2 1/2 years the last 5 years
nat days are what cost me i take about 500 note to blow
mark
mark
ive got piles of receipts... i stoped counting how much I had spent on it when it got over Ł5k... I bet including buyin the car and all the bits Ive bought its well over Ł10k, and ive only owned the car for a year!
Its an on going project.... you'l never finish, as your always tryin to get more out of it...
Im currently got another shoping list of Ł2k for big brakes, NOS, and water injection then im gona call it a day sell up and get a cozzy!
10k in a year..not being noisey but how much do you earn?..bet ya got no bills tho!..no kids..no rent!...nothing else just ya nob to look after as the saying goes!
how much ya gunna look for when ya sell up?
i dont ern enough, Ive stoped the mad spending now as im gettin to the end, I went the spares day at doningon last month and I only spent Ł30! last year I spent over Ł500.... you get to a point eventually where your about finsihed..!
looking for as close to Ł5k as possible...or a px towards a 3 door cozzy!
mines just a toy which never gets used lol and i got 3 kids with them the misses and the bloody garden i dont think im ever going to get mine on the road
mark
mark
steerfromdarear
28
29-01-2016 06:14 PM
