Escort Range Ford Escort RS1600i / Mk. 5 & 6 / XR3 Discussion.
St170 into mk4 xr3i
Old Jul 29, 2024 | 07:51 AM
Jayj1973's Avatar
Jayj1973
Default St170 into mk4 xr3i
I know it's been done but I want to get the idea of how hard this swap is. Also is there any chance of being able to use the 6 speed st box at all? Hopefully someone can help. All help will be appreciated.
I have a 1988 xr3i which has all been restored but now I want to put the st engine in now!
Old Jul 29, 2024 | 08:05 AM
haz87's Avatar
haz87
You can fit the box, but you'll need custom mounts and a bit of work on the inner wing to create the room
Old Sep 28, 2024 | 05:36 PM
studabear's Avatar
studabear
Pretty sure the inner wing/chassis leg doesn't need touching like when fitting the MTX75.
Like said custom mounts, driveshafts, hydraulic clutch conversion, speedo will need a work around.
I also believe the shift tower on the 6 speed conflicts with the brake servo set up so agaiin that needs potential work around.
Mike Sherwood
Escort Range
Apr 10, 2017 02:20 PM
We_The_People
Mar 18, 2013 09:11 PM
SLIM
Ford Mondeo Including ST
Jun 28, 2007 10:02 PM
