problems
borrowing me mates g-plate rs turbo over this weekend but there seems to be a problem. when u give it some the engine cuts back about 3-4000rpm aand theres no more go unless u let ya foot off then reapply. even then it only climbs a little until doing it again. its the same in every gear. almost like theres some sort of limiter cutting in. as far as he knows the car is completely standard other than a 3" magnex exhaust. any help would be brilliant
dave
dave
yea its over boosting mate!!it means the cars reached its maximum setting for the boost on the ECU, get a boost gauge and see how much its running, if its got a bleed valve turn it down or shut.
it will fill like someones slamed the brakes on (not actually breaking but accelerating)
brilliant. it aint gotta boost gauge but i'll plumb in the one from my cossie to see what its running then i can set it back to what it should be. what should it be set to with standard ecu?
cheers again for al ya help so far
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
