i have an 89 S2 and was just wondering if the intermittant wiper speed controller from a 90 spec can be fitted. its it just a case of chaging the control stalk, or is there additional wiring involved?
i believe that there is a extra pin on the plug for it, and also the relay has a extra pin, so ya need the laterspec relay, the free pin join it to the free pin on the switch and will work
I just put 1 on my f 88 erst last night it takes about 20 mins and works perfect.you take the steering shrowd off (4 screws) then take off stalk (2 screws) then take multiplug off then chang over. dead easy...
ummmm and the intermittant will work but does its intermittant rate change between max setting and min? Don't think it will if you have not modded the wireing at all
[color=red]Does the intermittent switch actually click or is it on a pot I have just been given one that doesnt click same as the one i have got that doesnt work
