Will a diesel box fit my RST?
Old 03-11-2008, 10:05 AM
adam.d
adam.d's Avatar
Default Will a diesel box fit my RST?
Need a box for my (S2 1988 F) found a cheap mk4 diesel box, will it fit and work ok?
Thanks in advance.
Old 03-11-2008, 10:06 AM
stembo21
stembo21's Avatar
Thanks in advance.
yer mate it will go in no probs
Old 03-11-2008, 10:08 AM
grsford
grsford's Avatar
yes mate will go in no probs as said, if you need another i got one here 2
Old 03-11-2008, 11:30 AM
antony215
Escort Rs Turbo
antony215's Avatar
As said it will fit but you wont have an LSD and contrary to myth the diesel box is NO stronger! if i were you id get another rs box or rebuild yours
Old 03-11-2008, 12:18 PM
cozmeister
More boost Igor!
cozmeister's Avatar
I agree. And, as you've found this diesel box 'cheap', have you asked yourself "Why is it cheap?" It's probably cheap for a very good reason!
Old 03-11-2008, 01:04 PM
Karlos G
Balls Deep!
Karlos G's Avatar
Torque steer here we come!
Old 03-11-2008, 02:26 PM
Christian and Beccy
#1 in Spelling Club
Christian and Beccy's Avatar
Diesel box will appear stronger due to the longer ratio's. The power is laid down more progressively, which is bound to be a little kinder to the transmission.
However, as others have said, a 'cheap' gearbox can't be a good gearbox really.
Old 03-11-2008, 04:27 PM
kiddie
kiddie's Avatar
My old white RST had a Ł20 diesel gearbox in for a year with NO issues. So you might be lucky mate. It was only mildly tuned though with chip, 14psi etc
Old 03-11-2008, 04:33 PM
bigstee1
bigstee1's Avatar
i have the Torque steer problem but im not running an lsd box just standard 16i box when it comes on boost it chucks me all over the place but im running a cossie blower which dont help the situation i would be investing in an lsd box tbh
Old 03-11-2008, 04:38 PM
phil_rs
yam yammer
phil_rs's Avatar
You can pick up a good lsd box for around Ł100 and they drive so much better with them
Old 07-11-2008, 12:40 AM
Grandad racer
Grandad racer's Avatar
the reason diesel gearboxes are cheap is becouse they so easey to find,how meany escort vans did ford make? far more than the rs turbo!! i paid 40Ł for my dieasl gearbox 4 yrs ago, and its still going strong on my rs, similar gear ratios aswell, im happy with it!
Old 07-11-2008, 09:28 AM
Karlos G
Balls Deep!
Karlos G's Avatar
My RS came with a Diesel box and the gears are so much longer it's crap, you may gain top speed but the acceleration you loose is not worth it and like I said earlier torque steer is crazy if your runnig any sort of power!
I now have a S2 box (LSD) and it's much nicer!
Old 08-11-2008, 10:52 AM
marky_g
Fleet Manager
marky_g's Avatar
dont fit it unless u rely have to
Chas
21-09-2015 08:57 PM
Billy_RS
15
05-09-2015 12:04 PM
A.t.p
15-08-2015 11:37 AM
druidgetafix
15-08-2015 10:22 AM
dlwarrior
05-08-2015 10:19 AM
Quick Reply: Will a diesel box fit my RST?
