alloy catch tank swirl pot??????????
hi everyone.
can someone please explain what alloy catch tanks and swirl pots are for and what are the benefits.
many thanks once again
Catch tank seperates and catches oil from the your breather system, benefits are that you'll be removing the stock breather system which is crap and has potential air leaks everywhere!
Swirl pot does fuck all as you already have one in your thermostat housing
Benefits are simple, better breathing and the larger tank won't get clogged up as quickly, forcing excess oil through the induction side of the turbo.
Oil vapour can rapidly reduce the octane level of fuel by contamination of the combustion chamber. By diverting this vapour and allowing it to condense in an oil catch tank, you not only remove this vapour and unwanted crankcase pressures, but also help reduce the chance of piston detonation.
lol yes it does!
Bang on mate!
Mine breathes to atmosphere so i have no oil vapours going back into my system at all!
