how do i relocate battery to the boot
as stated i want to move my battery to the boot do i literally just cut the battery tray out weld it in the boot and extend the wires and run them down the side of the interior trim
Balls Deep!
lol! Why would you need to cut the battery tray out and weld it in the boot??
Just move the battery and run a big fat live wire from the battery to the engine bay where the battery used to be, connect all the lives to that, earth the battery Negtive tetminal to the body somewhere in the boot, and then any earth wires in the engine bay to the body aswell!
Fleet Manager
your battery should also be in a box if its goin in the boot and must be bolted to the floor
its an easy job
something like 2 guage would be fine, run it to a distribution block and take everything from there, dont forget to stick a fuse right near the battery as well, this is to protect the wire incase it rubs through somewhere.
Fleet Manager
is 2 guage 2awg or around 40mm squared in idiot language as that's what i've got says it can carry 350 amps contineous and is the size of my finger
Yes it is 2 American Wire Guage.
Just put a 350amp fuse as close to the battery as you can and run it to a distribution block, or as others have said just use a bolt. But i think a proper block looks better.
07-10-2015 12:56 PM
