Breather filter fitted on the rocker cover
I have fitted a breather filter on my rocker cover. Now I have got a new problem in my car. The hole car smells old oil from the breather filter. It smells awful inside the car and also outside the car. When I have parked the car in a parking spot, people turn around and lookes at me and my car.
You guys that also got a breather filter fitted on the cover, do you have the same problem?
BR Butchi
BR Butchi
Lots of Motorsport companies do them
http://www.randbmotorsport.co.uk
http://www.burtonpower.com/company_info.aspx
they work by collecting the oil passed through the breather hole and re-circulating it back down to your sump- they will also require a filter of some sort but will not smell half as much if at all
What is it you've put on there? is it a oil seperator? Thats what i have and 2 pipes from the rocker go to it, the other goes down to the metering unit then the other goes down to the bottom of the block for the oil return, oh and then a vacuum pipe goin from the oil seperator to the left outlet on the inlet manifold.
no, as the oil can cause det for one, it's legal emissions requirement though. You should have a seperator, and then vent this with a pipe to the back of the car.
focus rs 1672
just run a pipe from the breahter return and vent it under the car,thats what i done,still get some oil smell when sittin in traffic but leasy its no pouring fumes in thru the vents
JoeyBoyden
18-08-2015 10:52 PM
track.focus'd
12-08-2015 05:53 PM
