gear problem
Old Oct 16, 2008 | 01:07 AM
Maxxeh's Avatar
Maxxeh
Default gear problem
Ive installed the BnM short shifter with a new gear selector rod. However after the engine gets warm, it gets hard to get it into gear. When I try to put it into reverse it will always make a grinding and whinning noise. I've got an AP organic stage 1 clutch.
Will I need to get the mk5 pedal conversion to fix this problem? If so, what parts do i need?
Cheers.
Old Oct 16, 2008 | 07:50 PM
Moonie's Avatar
Moonie
They all grind a bit when going into reverse its just the clutch dragging slightly. If you have the AP clutch then the Mk5 pedal/quadrant will help as it pulls more cable for the same ammount of pedal travel (bigger quadrant) and will help the clutch disengage more.
See here - http://www.apracing.com/info/info.as...difications_90
The ford part numbers are on that link aswell.
cameron2
Sep 20, 2015 04:30 PM
Rammer46
Sep 18, 2015 08:31 AM
Flateric_2002
Sep 15, 2015 08:41 AM
Marino
Sep 12, 2015 11:10 AM
