No boost... HELP!!!
I was just driving home and lost all boost it was fine 1 minute then fcuked the next. Now the car sounds like crap and the turbo dosnt sound like its even spinning and the boost gauge wont go above 0 psi. Any ideas???
Thanks in advance!!!
Yeah car idles just wont come on boost. Just had a look for boost leak defo not that. A mate suggested map sensor prob the cause but unsure till hes looked at it properly.
Balls Deep!
Nothing to do with the 'Map' sensor mate, the ECU only adjusts the timing based on the 'Map', wouldnt affect your boost at all.
Could be the turbo shaft has got stuck, remove the boost pipe and make sure it moves freely! I had this happen on a turbo that had so much play in the shaft it would get stuck!
Gary Krishna
Sounds to me as if the actuator rods popped of and the wastegate staying open or something is amiss with the turbo itself.
I would think by the sound of things its more likekly to be the actuator rod popped off. They often lose the securing clip and fall off causing the symptoms your having.
Infact answer me a quick question bro!
When driving the car does it sound as if its lagging real bad, such as pop bang when hy rev?
No boost wouldnt be as above my post or ur timming as that effects the boost if out
NoGutsNoGlory
01-10-2008 08:14 PM
