s2 wont start
iv had my s2 3 weeks only drove it twice. was told the meter unit was worn so changed it. new fuel pump. its had new leads plugs, rota arm. diz.
iv cheaked the cold start valve. it will run for 3 to 5 secs then dies. could the imob be kicking back in.
grayzo
doubt the immobiliser mate its more than likely that it needs a set up mine used to do it till it was set up have u set it up since puttin the metering unit on also check the breather pipe on the bottom of the metering unit
iv had a tuning guy out he set the timming and diz up but he can only get it running for 6 secs then it dies. it will bump start and run but if i turn it off and try and start it it wont start
DixieTheKid
11
06-06-2020 11:20 AM
TPM961
15-01-2018 10:50 AM
