Cabriolet turbo conversion
i'm in the process of making my efi cab into a turbo, i have used an escort rs turbo bottom end with drilled cps and used the efi head from the cab, am using a new t3 turbo, and ofac ecu. just wondered what i do about the amal valve pipes that go on the turbo as the car doesn't have an amal valve, do i need to add an amal valve or can i just block these? also will the efi xr3i loom from the car just plug into the ofac ecu and work? do i need to use a fiesta turbo map sensor? what else do i need to do?
http://www.rsbible.co.uk
if you dont find all you need to know on there pal drop me a pm ive just done all this myself to my cab
JK12
33
26-04-2021 12:09 PM
Matt Baxter
16-09-2015 08:30 PM
23
12-09-2015 12:56 PM
