kent cams
03-11-2008 | 10:59 AM
03-11-2008 | 12:06 PM
i thought it was good allround power.....but full boost cm for me everything after3g or lower with a rollerbearing tubo
03-11-2008 | 12:11 PM
ive got a kent35 in mine went well before the bottom end went on its 1st test drive
03-11-2008 | 01:42 PM
mmmm yea i heard the 35were good told the 22 werent anygood for a turbo tho
i only want summit to lick in till the turbo takes over tho
03-11-2008 | 01:43 PM
03-11-2008 | 02:25 PM
For the 500th time, Kent Cams for the CVH are poop. There are plenty of other discussion threads in this room to this effect.
03-11-2008 | 03:24 PM
yea christian i only wanted the head as its had so much work done but the cam is included for free so was seeing if its worth keeping in
03-11-2008 | 03:28 PM
Yes, would make a great paperweight.
03-11-2008 | 03:39 PM
Quote:
Originally Posted by
Christian and Beccy
LMFAO!!
To true!
03-11-2008 | 05:49 PM
Ive got a kent 35 in mine and is still running sweet as a nut. ive only done 8thou miles mind you but no problems so far.
03-11-2008 | 05:55 PM
i had a kent cvh 35 and diidnt last long.in the end it put my timing out and damaged my pistons
01-11-2015 06:53 PM
Mc5506
05-10-2015 09:57 PM
