efi vs mfi ????
orion=mini saff
efi loom,ecu,head or adapter plate,bottom end trigger wheel,unless u got the hole in the block for the CPS,map,inlet manifold coil pack and leads few other odds and sods.
Dont like EFI much myself,but other do, would rather go cossie managment or aftermarket for the effort
I ditched my MFI a few months ago for Coz Mgmt and the change is better than i could of imagined! It starts 1st time every turn of the key whether the engine hot, cold or if its been stood for weeks! Well Impressed
awrite, if ur thinking of doing the swap over. iv got a fiesta turbo head and inlet manifold with new gaskets and new head gasket there aswell. not wanting much for it ,comes with coil pack ,alot easier to tune supposedly
before bothering with the swap ask the following questions... how much power do you want out the car? what do you use the car the for (daily driver? weekend thrash \ second car ?) are you just going to EFI cos some bloke down the pub said it was better?
Just think about all these things and make "an informed decision" efi and MFI both have their advantages and weaknesses!
MFI
downers.
Metering heads can be fragile and expensive to replace
loose one sensor they run like a bucket!
injectors leak and they fire on 2-3 when starting up! (not always!)
uppers
Can get 200bhp easy with big boost, big intercooler, exhaust, and 98 petrol.
fairly simple to fix faults
ability to "home tune" with simple tools (3mm allen key, 10mm spanner gas tester and timing light, although I dont recomend this!!)
efi
downers
need to change injectors for each stage of tune (injectors are different to other efi systems ie cossie)
mate of mine was prone to melting pistons on efi
uppers
TURBO CHATTER
starts up better than mfi
some say smoother in operation
slightly better mpg
MFI
downers.
uppers
efi
downers
uppers
TURBO CHATTER
slightly better mpg
Norris Motorsport
An MFI equiped RST if running 100% perfect is in fact probably smoother and more refined than any EFI setup. KE jet is actually a fantastic system, let down only by the fact it is getting old now.
Hence we usually advise if you have no plans to go beyond 200bhp, we would advise having the MFI system fully checked and repaired/setup as appropriate to make good. We can restore any KE equiped car to run as good as new, usually for sensible cost!
If planning to go beyond 200bhp, go straight for cosworth management.
In terms of power for power under 200bhp you will gain nothing by changing the KE jet IF the KE jet is setup and working properly.
The very fact that you can change injectors is not a downer as you suggest it is an advantage as it allows you to have a tactile and high performance engine without wasting fuel.
If your mate was melting pistons, it did so for a reason which was not to do with the type of management on the car, sounds really really badly set up to me
Fleet Manager
its only worth doin if you are goin with cossie or aftermarket management
mate of mine did it had a stage 2 erst making about 200bhp on mfi swapped to standard ofab efi and got standard car power fiesta turbo managment is very expensive to set up compared to mfi
like everyone said if you changing management you need the efi bits anyway
its a good mod but to get you car to even stage 1 on efi will cost you about Ł200 for a chip, Ł50 for a decent filter, and not sure about beige injectors about Ł200 again id imagen the a set up about Ł200
#1 in Spelling Club
My car is on EFi and certainly NOT Cossie management. It was the best move I made. IMO, this only applies though if the management you choose is high quality and therefore can provide precise control and nice features etc. My ECU runs closed-loop fuelling and boost amongst other things.
My set-up uses 630cc injectors, which are PLENTY big enough for anything I can do to it, but it idles at 14.7:1 and I reckon it will do 30-35 mpg.
I just cannot see any reason for staying with MFi, other than cost. A decent modern ECU will cost around Ł1k for the ECU and loom (plus fitting and mapping) and is worth every penny IMO.
Although, as Karl says, it is possibly overkill for sub 200bhp.
my escort is a 1.8zvh newman cam/pulley airtek full front mout zaust and a standard t3, not been out on road yet hence not been set up so i dont no its power output, if mfi is sufficent then ill just stick with that haha
