Adjustable track control arms
Hi ive seen these for other cars but do they do a set for a S2 , ive got coil overs and ive still got slight negative camber and would like to adjust it
Thanks
Thanks
Originally Posted by NUTS RuS
Slight negative is good (depends on how far you mean slight though)
We have them in stock now, and are a very popular conversion mod for lowered or track cars![Top](https://passionford.com/forum/images/smilies/smile011.gif)
Thanks
OCD Victim
Also, do you have a set for a normal 2WD Sierra?
The MEF new design does away with the offset spacing required on the rose joint and keeps the caster angle the same on road cars.
They come preset to standard length from the jig, so you can safely fit them and run around on them for months before you need to get them checked over or set up to help with your geometery.
They have a better competition spec rose joint than the other ones on ebay, and have centralised spacers so are suitable for both Mk3 & 4 Escorts.
If you alter the angle at the bottom of the wheel, with adjustable TCA's then the angle at the top of the strut will change too. This on a roadcar is obviously a rubber bush.
If your new angle is pushing hard on the rubber then its natural instinct is for it to push back.
The spherical bearing takes up this angle with ease without it straining the components.
We are out of stock on the Escort ones at the moment as they are quite popular with track and modified cars in Europe. Just waiting on the aluminium bar to come in before we can make some more
We are out of stock on the Escort ones at the moment as they are quite popular with track and modified cars in Europe. Just waiting on the aluminium bar to come in before we can make some more![Top](https://passionford.com/forum/images/smilies/smile011.gif)
Yep just drill and tap it to fit as normal as they normally fit below the top mount ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
also one more quick question , i notice that my rear wheels also look like they have a slight neg camber , will your rear trailing arms sort that out ?
Thanks
No Trev - the trailing arms can't adjust rear camber.
A simple quick fix is to elongate the hole in the chassis on the inner end of the wishbone mounting point.
SMILER258
28-09-2015 09:04 AM
