RST ABS
Old Sep 6, 2007 | 03:47 PM
cossiestu's Avatar
cossiestu
Default RST ABS
My mrs escort has just failed the MOT, as there is no N/S ABS belt....
Whats the easiest way (if there is one!? ) to fit a belt?? I assume you need to get the driveshaft out?
Old Sep 6, 2007 | 04:49 PM
djmillsy's Avatar
djmillsy
Fife Radge
you have to take the drive shaft off to fit the belt or get rid of the whole abs system
Old Sep 6, 2007 | 07:35 PM
dave green's Avatar
dave green
Put a cable tie round the belt tentioner to keep the light out. ABS is crap on S2 RSTs
dave
Old Sep 6, 2007 | 10:07 PM
djmillsy's Avatar
djmillsy
Fife Radge
dave
thats a severe understatement
Old Sep 6, 2007 | 10:57 PM
jayjay's Avatar
jayjay
cable tie round the senser mate if its still got the sensers if not just pick a feed of the park light
Old Sep 7, 2007 | 09:50 AM
cossiestu's Avatar
cossiestu
Unfortunatly, the tester has clocked the belt is missing, i tried to 'bodge' it, but he said he wont pass unless the belt is on...
Might try to put the belt over the hub and slide it down the driveshaft, (if it will...?) dont really want the risk of pissing gearbox oil everywhere!!
Old Sep 7, 2007 | 10:39 AM
dave green's Avatar
dave green
Its as the first post then
Dave
Old Sep 7, 2007 | 11:14 AM
cossiestu's Avatar
cossiestu
Dave
Thats what i was afraid of!!!
Old Sep 9, 2007 | 04:19 AM
escorted series 1's Avatar
escorted series 1
How hard is it to remove the abs.Wanna do it properly and not just cut the belts like my mate told me
Old Sep 9, 2007 | 06:55 AM
djmillsy's Avatar
djmillsy
Fife Radge
you have to take the modules out hers a diagram that someone showed me off here of what to do
Old Sep 10, 2007 | 06:03 PM
Moonie's Avatar
Moonie
I don’t think the belt will go over the complete hub. I would leave the shaft in the gearbox and remove it from the hub.
If you are going to remove the abs you will need to bypass the modulators. I did mine when I had the engine out so just run two new pipes from the master cylinder down to the two t-piece’s on the inner wings.
You will also need to blank off the return hoses at the fluid reservoir or get a non ABS reservoir.
Old Sep 13, 2007 | 10:06 PM
jayjay's Avatar
jayjay
did you get it sorted pall
Old Sep 14, 2007 | 06:32 AM
Hrsturbo's Avatar
Hrsturbo
sorry to jump in but when blanking off the two returns at the reservoir can you cut the original pipe and link them or are they different pressures?
thanks
Old Sep 14, 2007 | 03:33 PM
Moonie's Avatar
Moonie
You can link them together, theres no pressure in the return pipes once disconnected.
Old Sep 14, 2007 | 03:34 PM
Hrsturbo's Avatar
Hrsturbo
tankybaby66
Feb 6, 2016 02:24 PM
A.t.p
Oct 23, 2015 07:54 PM
