clutch slip on boost
Hi guys, my car peaks 1.2bar and holds 1bar, but some times now and then it starts slipping, the car is meant to have a black diamond clutch in there
any ideas?
any ideas?
Clutches are the weak areas of RST. Most are not capable of much and even then the prices are terrible. Nohing is more frustrating that showing ££ on an expensive item just to find out it wasn't good enough.
Anyone know of a reasonable priced 220mm sprung paddle plate?
the flywheel has been skimmed it shows it in the receipts
bollocks, the clutch then, whats a good clutch to go for?
the front tyres light up as its pretty powerful trying to put power through 14inch clover leafs
sticky cable?
oh yeah, cluth is a few months old too, duno if it needs running in as they previous guy didnt use the car that much
sticky cable?
Yes I have had the same problem on mine last week
The arm on the gearbox can get sticky -
make sure this works freely or your clutch does not engage onto the plate properly!
This with a flywheel skim solved my problem
Cable,
Take cable off clutch arm,
it should be smooth to pull by hand, with resistance from pedal wieght.
Rachet,
you should be able pull the clutch release arm by hand towards front of the car when pedal released?
but will be heavy.
if both of them are fine, then time for new clutch and skim.
Rachet,
but will be heavy.
Mark RS
12-10-2015 06:01 AM
Russ Payne
25-09-2015 08:29 PM
