rs turbo exhaust
rs turbo exhaust
hi all,
I need big bore exhaust on rs turbo with 1,4 bar boost?
My car running with stock back box, what can happen?
thanks for help
thanks for help
Hi
Is the 1.4 a peak or are you holding that pressure?
Would be interesting to know engine/turbo/remap spec if you are...I need to get around to mine soon...any tips appreciated.
I used to run 1.2 peak and went from standard exhaust to large bore scorpion (whole system from manifold back) and that made the turbo come in much earlier - with 1.4 you should get a decent manifold back system really.
Would definitely recommend it
Hi
MegaSquirt MS3, stanfard camshaft, bosch 440cc injectors, t3 stage3, foged 7,5:1 pistons, forged con rods ths performans, balanced crankshaft, stage 3 head, standard exhaust system and back box standard. AP racing clutch, standard ford head bolts and head gasket burton power.
will be reliable is that?
using only 76mm back box scorpion or others, and pipe stock, is good?
thanks
That sounds like a nice spec
would have expected an uprated intercooler on your list though for sure...?
not sure how reliable that will be, sorry, but you there is a lot more setting up to do there than that required for 1.2 bar! hope you are getting the fuelling/timing set up properly - are you using an adjustable pulley with the cam?
My advice would definitely be to get a full system from the turbo back - not necessarily scorpion, just the least back pressure system, especially with that spec
yes, a large front mount intercooler is fitted (radtec)
I have the adjustable pulley, but I have no cam.
I had a chip motorport developements, beige injectors and 15psi of boost, but the car running very hot and air fuel racio was not the best, so switch to the MegaSquirt.
definitely have to change the exhaust system.
thanks for help
Matt Baxter
16-09-2015 08:30 PM
rsstav
Ford Focus RS Parts for Sale.
20-08-2015 07:45 AM
