forge actuator
Old Aug 30, 2011 | 06:06 PM
ethan89's Avatar
ethan89
frst
Default forge actuator
hi guys my rst has a forge adjustable actuator fitted but even wound tight as poss it is still only boosting at .65-.7 bar was wondering do i need a new spring an where to buy or can i just cut and shorten the actuator bar and wind up further??need to wind up boost as have a 195 superchip and beige injectors
Old Aug 30, 2011 | 06:13 PM
rstdave's Avatar
rstdave
Give forge a ring, the actuators are servicable so you can take them apart and replace the spring.
I'm not saying that is definatel the problem mind but would rule the actuator out anyway
Old Aug 30, 2011 | 06:58 PM
Karlos G's Avatar
Karlos G
Balls Deep!
How much preload is there with it wound all the way in?
Old Sep 2, 2011 | 12:24 PM
ethan89's Avatar
ethan89
frst
its tight enuf i gues but theres still half inch i play id say
steve.rst
Mar 15, 2016 08:01 AM
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
A.t.p
Sep 29, 2015 05:04 PM
richierich1986
Sep 18, 2015 03:29 PM
mattxr3i
Sep 13, 2015 05:52 PM
