cts stage 2 box
Old 28-08-2011, 12:52 PM
Roscopeco
P8 Managed S1 with ALS
Roscopeco's Avatar
Default cts stage 2 box
Im going to go and get a cts stage 2 box , can anyone advise me on what to look for ? What do the atb's look like from where the driveshafts go ?
Thanks , Rosco
Old 28-08-2011, 01:07 PM
conor.rst
conor.rst's Avatar
why dont go you mtx 75 ?
Old 28-08-2011, 03:04 PM
Roscopeco
Roscopeco's Avatar
because cts stage 2 has quaife atb !
Old 28-08-2011, 04:35 PM
luke19790_3
luke19790_3's Avatar
How much is the cts box?
Old 28-08-2011, 04:46 PM
Roscopeco
Roscopeco's Avatar
why do you ask ?
Old 28-08-2011, 04:49 PM
luke19790_3
Think when I looked it was over a grand, for the price you get something better
Old 28-08-2011, 04:51 PM
Roscopeco
Roscopeco's Avatar
Yeah 980 ish for stage 2 with quaife ! Im looking at a 2nd hand one though just trying to make sure its got the ATB in it before i decide to buy it !
Old 28-08-2011, 04:56 PM
Danster76
Danster76's Avatar
Looks like this and stamped on the top should be a number which is individual to each CTS box. You can then call CTS and they will be able to identify it and tell you the spec and when they built/ serviced it.
The ID is stamped on the flat near the selector.
Old 28-08-2011, 06:28 PM
xr2wishy
Bodger of Blackburn
xr2wishy's Avatar
this man raises a good point, for around £1500 you get frs/mtx75+quaife diff box and all associated parts to fit a FRS box.
does mean a bit of work for you and sourcing parts, but will get you a very, very strong gearbox with the diff you're after.
gets a cable changer in there, hydraulic clutch and electronic speedo.
Old 28-08-2011, 07:42 PM
Roscopeco
Roscopeco's Avatar
Thanks for that mate i'll be sure to do that
Old 28-08-2011, 08:09 PM
CasperR
CasperR's Avatar
Karlos makes a good point in this thread regarding ib5 vs cts boxes in my opinion.
https://passionford.com/forum/ford-e...x-fitting.html
Old 28-08-2011, 08:17 PM
rs_traynor
stage4 2wd cosworth
rs_traynor's Avatar
had one of these in my 2.1 s2
Old 28-08-2011, 09:29 PM
jonny s2
jonny s2's Avatar
think they have the markings starting with JP
some boxes hold out some dont, at the end of the day its your choice,and desired goal you want to achieve
a mate of mine had a cts2+ and had 280ish hp and drove it hard all the time, and it lasted for him
Old 30-08-2011, 11:58 AM
1223456's Avatar
so does the focus rs box, but its actually cheaper and also stronger
Old 31-08-2011, 09:37 PM
Roscopeco
Roscopeco's Avatar
As it turns out the box im buying is a stage 2+ and is at a very good price so i doubt an RS box would come in at the same money !
AJC
08-10-2015 11:09 AM
gcfcos
59
06-10-2015 05:04 PM
Mc5506
05-10-2015 09:57 PM
deathrider666
28-09-2015 06:12 PM
Russ Payne
25-09-2015 08:29 PM
Quick Reply: cts stage 2 box
