rear disc conversion
hello fitted a rear disc conversion consisting of cosworth 4x4 discs and callipers and they don't seem to be releasing. on the jack you can spin the wheel and press the brakes and then spin it again fine but drive round the block and they get very hot. any one else experienced this problem
heres my twopence worth ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
i bought a convesion but i have to pick it up and fit it yet ,but from what i seen and was told by the chap it has a mk5/mk6 handbrake cable as the calipers work the opposite way to the way the oldsystem worked so could it be when the handbrake is off the brakes are actually on if you know what i mean
My rear disc brakes was letting on because of rear axle compensators. Bypass those and brakes will release completely. Altough brake balance is ruined.
I suggest you change drum brakes back with original compensator setup, rear disc conversion is shit i say.
Its a strange one when I unbolt the rear wheels the brakes don't stick on which is strange as the caliper slider bracket is central to the disc and the caliper centres uts self. I'm going to wind the caliper in later bolt the wheel on then press the pedal so it meets the disc how it should can't see it making any diffrence though lol
There binding, where did you source the calipers? They do have a common problem for seizing, so if you got second hand etc. Also a collapsed hose can cause this.
The cable is fine by the sounds of it, as the problem is only apparent once you start driving the car and you say the levers are releasing.
Martin
Martin
Irs strange the calipers are working fine ther are not seized hand brake lever is free and working perfectly and when the wheels are off they work fine and are releasing fine its when the wheels are put on the problem starts like the slider brackets are seized not letting the calipper ceter its self but the slider brackets are also freely moving lol
It sounds like the spacers between the caliper and the mounting plate arent the correct size. It binds with the wheel on because the disk is pushed against the rear pad.
Take the spacers out and measure them, IIRC they need to be 9mm.
To test, add washers to the spacers to increase the size untill they work again, then get some new spacers made to the correct thickness.
My rear disk conversion works absolutely fine without compensators on an XR3i master cylinder. No bias valve either and it passed an MOT 2 weeks ago with no wheel drag and adequate force.
Lee
Lee
