using st170 pistons with det marks
Old 02-09-2011 | 03:40 PM
luke19790_3's Avatar
luke19790_3
Default using st170 pistons with det marks
will get a picture up in a minute but can you reuse pistons with det marks?
Old 02-09-2011 | 03:57 PM
luke19790_3
Old 02-09-2011 | 06:32 PM
Karlos G's Avatar
Karlos G
Balls Deep!
As long as the pistons are 100% intact yes, remove all the rings and check the rings lands very carefully for cracks and of course the rest of the piston too.
Shows how much those pistons can take if they are intact as that's quite nasty det marks!
Old 02-09-2011 | 07:03 PM
DazC's Avatar
DazC
You need to switch on the macro function on your camera or back off a little to let the camera focus on the piston crown!!
From what I can see on the top picture, those marks are not det marks. They are impact marks...
Old 02-09-2011 | 07:08 PM
Karlos G's Avatar
Karlos G
Balls Deep!
I was thinking that but as you say it's hard to tell from the pics.
Old 02-09-2011 | 09:01 PM
luke19790_3
Old 02-09-2011 | 09:03 PM
luke19790_3
any better?
Old 03-09-2011 | 08:27 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
The sides look like they have picked up from what i can see, this would be more important then the marks on the crown that i can see.
Old 03-09-2011 | 08:50 AM
creator's Avatar
creator
As jano said there seems to be score marks on the side of the piston,have you stripped the engine they came out of?
Old 03-09-2011 | 10:43 AM
luke19790_3
only have the pistons/con rods, one piston with marks the other look ok
Old 03-09-2011 | 11:29 AM
DazC's Avatar
DazC
All used pistons will have a degree of skirt wear/markings. If they are not too deep then they'll be fine. The marks on top are impact marks from some debris. They're nothing to worry about unless the ring gap has closed up.
Old 03-09-2011 | 03:39 PM
Canada1's Avatar
Canada1
Agree!
Measure the ring clearance - not end gap. This will let you know if ring groove width has been
affected.
Old 03-09-2011 | 04:32 PM
luke19790_3
ok thanks will have a look later
Old 05-09-2011 | 04:07 PM
rsmark86's Avatar
rsmark86
Hello mate I brought them from jpa on here,
I have got another piston you can have, but the bottom cap for the rod is missing so you would need to use the rod on the worn piston
I'm in Portugal till the 16th but can send it or take to national day mate
Sorry for any inconvenience this has caused
I will sort you out when I'm back mate
Old 05-09-2011 | 06:09 PM
luke19790_3
Thanks
pm'd
Old 08-09-2011 | 11:00 AM
rsmark86's Avatar
rsmark86
Replied mate no problems
Old 25-10-2011 | 09:07 PM
luke19790_3
have you had chance to post the piston?
arkeye
Ford Focus ST
20-02-2016 01:22 PM
01-11-2015 06:53 PM
deathrider666
28-09-2015 06:12 PM
Sp3no
27-09-2015 07:23 PM
Marv888
26-09-2015 03:44 PM
Quick Reply: using st170 pistons with det marks
