Help with fitting ST170 brakes (Front)
Old 01-08-2011, 09:44 PM
Joe91
Joe91's Avatar
Default Help with fitting ST170 brakes (Front)
As per title, im not sure what i need to do to make these fit, ive been told i need a spacer kit or something to make them line up?
Ive got the ST170 calipers with bolts and brackets and ive got the disks and pads..
Does anyone have any experience in fitting these? I need to fit them by ford fair so im desperate!
Thanks, Joe
Old 01-08-2011, 10:02 PM
Karlos G
Balls Deep!
Karlos G's Avatar
You need only the ST170 discs mate, then MK3 Mondeo pads, calipers and 12mm spacers.
Old 01-08-2011, 10:10 PM
Joe91
Joe91's Avatar
Where can i get spacers? Also do i use the bolts and brackets off the st170 caliper or the ones of my erst calipers?
Joe
Old 02-08-2011, 07:07 AM
luke19790_3
luke19790_3's Avatar
Did you get the link for gat tuning?
Old 02-08-2011, 10:44 AM
Joe91
Joe91's Avatar
Yeah i did thanks luke, i sent them a message but no reply..Just getting desperate to have them done for ford fair! can you help on spacers karlos?
Old 02-08-2011, 11:13 AM
dojj
Resident Wrestling Legend
dojj's Avatar
You need to drill out the hubs to take the bigger bolts, but the rest should just bolt on
Remove your callipers and trial fit the other brakes, remembering to use some wheel nuts to hold the disc firmly in place. And if every ting works you only need to sort out the brake pipes and bleed the buggers and job done
Old 02-08-2011, 11:17 AM
Joe91
Joe91's Avatar
Ok will my standard hoses fit on these st170 calipers?
Old 02-08-2011, 12:52 PM
dojj
dojj's Avatar
depends if the fittings are the same or not
they are either straight fit or tapper fit, i can't remember which buti had to change mine ont he fiesta
Old 02-08-2011, 05:27 PM
luke19790_3
if you have some 12mm metal, you could make your own
Old 02-08-2011, 09:26 PM
Joe91
Joe91's Avatar
Mmm just annoying as I was told these were a straight fit, I'm not one to do my own work on my car and there's no chance of getting it done by FF!
Joe
Old 03-08-2011, 06:50 AM
Rogeyboy
Rogeyboy's Avatar
Joe, its not alot of work m8... Just drill the holes out and bolt the 12mm spacers and calipers on... Standard hoses fit - altho as you are upgrading it would be a good idea to swap them for braided hoses
Old 03-08-2011, 08:18 AM
Joe91
Joe91's Avatar
I can't get hold of any 12mm spacers though...
Old 03-08-2011, 08:28 AM
luke19790_3
Its just a flat piece of metal 12mm thick with two holes in.
Old 03-08-2011, 08:47 AM
dojj
dojj's Avatar
why do you need to make a bracket when the ford stuff just bolts into place?
Old 03-08-2011, 08:48 AM
luke19790_3
Thinking about it I do have the brackets sitting in my garage.shame you're not closer
Old 03-08-2011, 09:43 AM
Oranoco
Oranoco's Avatar
I don't remember using spacers on my ST170 conversion at all, are you sure they aren't Mondeo V6 brakes you have?
I might be way off the mark though as mine were done about 6 years ago.
Old 03-08-2011, 09:52 AM
Karlos G
Balls Deep!
Karlos G's Avatar
12mm spacer are 100% needed or the calipers will not be central on the discs, in fact the discs probably wouldnt even go on! lol
Old 03-08-2011, 10:02 AM
Rogeyboy
Rogeyboy's Avatar
Ditto...
Old 03-08-2011, 10:35 AM
dojj
dojj's Avatar
all i did was this
then this
and with some of these
it all went like this
to this
Old 03-08-2011, 10:41 AM
luke19790_3
Think Fiesta's are different to escorts
Old 03-08-2011, 10:50 AM
luke19790_3
Old 03-08-2011, 11:11 AM
Karlos G
Balls Deep!
Karlos G's Avatar
Dojj thats not an MK4 escort though!! lol
Old 03-08-2011, 07:47 PM
studabear
studabear's Avatar
Dojj your brill,you fitted a 5 stud disc to a 4 stud hub
Old 03-08-2011, 08:17 PM
Local engineering shop would make some ,thick dowl, big enough hole through the middle for bolt ,like a thick looking polo mint really ,thats what i had on mine
Old 03-08-2011, 08:25 PM
Joe91
Joe91's Avatar
What do the brackets do though? Are they the same as spacers or do i not need spacers with brackets? Sounds dumb but i dont have a clue!
Joe
Old 03-08-2011, 08:40 PM
luke19790_3
same thing
Joe91
Joe91's Avatar
Does it make any difference that im using ST170 calipers, St170 disks and pads? Does it still mean i need the spacers as i know alot of you have used mondeo discs pads and calipers etc because they are cheaper?
Joe
Old 03-08-2011, 09:34 PM
dojj
dojj's Avatar
i simply fitted the stuff directly from the mondeo so it needed a little "fettling" to fit, but had i used the st170 discs they would have been a direct fit with no grindage required
also, i've been redrilling discs for years with no problems whatsoever as there is plenty of metal left between the studs, you just have to use a proper drill in a proper drill press and have a useable template to drill the holes in the correct places (i simply cut off the face of a 4 stud disc and then fitted it to a hub to centre it all up before drilling each hole AND i put bolts in to make sure the holes didn't move while i was drilling the next one)
Joe
the mondeo calipers are far more readily available and cost a fraction of the st stuff, but discs i would always advise to buy new, the ones i used had only done a few thousand miles and the calipers had been totaly overhauled so everything was tried and tested and working but if you were to get second hand stuff form the likes of ebay i would always recommened a rebuild just to be on the safe side
Old 03-08-2011, 09:37 PM
makaveli96
makaveli96's Avatar
What's needed to fit ST170 300mm discs with the 4x4 calipers on an escort rs turbo?
Old 03-08-2011, 11:10 PM
kermitt
kermitt's Avatar
Mk3 mondeo calipers, pads and the correct spacer kit obviously.
Old 24-08-2011, 02:52 PM
Joe91
Joe91's Avatar
Mmm so can anyone answer the OP of anyone actually fitting ST170 calipers and discs? Not mondeo calipers etc, St170 calipers and 300mm discs..Going to fit them on friday with a mate but just worried incase we get stuck without things we need. Must be someone on here with experience!!
Thanks, Joe
Old 24-08-2011, 04:22 PM
Rogeyboy
Rogeyboy's Avatar
I would guess the same as the mondeo stuff, its just the mondeo stuff is easier to get hold of and the calipers have a larger piston so more braking force!
If you have all the parts, mock fit it all up and see what needs modding to go where... It'll only be a case of spacing the caliper out by the correct amount (12mm with mondeo calipers - i dunno with the st170 ones) with a spacer plate or peices of thick wall steel tube.
Old 24-08-2011, 04:23 PM
zippyobrien
zippyobrien's Avatar
I put st170 disc and calipers straight on. You only need the spacers with mk3 Mondeo calipers
Old 24-08-2011, 07:41 PM
Pridzz
Pridzz's Avatar
Anyone find a link or pics for the so called spacers?
Old 25-08-2011, 07:09 AM
Rogeyboy
Rogeyboy's Avatar
Zippy - on a mk4 escort?
Old 27-03-2014, 06:09 PM
marky_g
Fleet Manager
marky_g's Avatar
Digging up and old on here but what about calliper bolts? Do you just use standard Mondeo stuff will it be long enough with a 12 spacer?
Old 27-03-2014, 06:28 PM
dojj
dojj's Avatar
good point
Old 27-03-2014, 10:31 PM
Jamie_EscortSport
Jamie_EscortSport's Avatar
Mark I got joes old 170 setup on mine now....they are normal m12 bolts with a med strength lock tight. I couldn't tell you the length off head but can measure. For you when I'm next up there ( if your in no rush)
Old 02-04-2014, 10:28 PM
marky_g
Fleet Manager
marky_g's Avatar
That would be brilliant mate
I've made my spacers now just need the bolts pmsl
Old 29-03-2018, 08:34 PM
Doodah
Doodah's Avatar
Awesome!
Quick Reply: Help with fitting ST170 brakes (Front)
