What's needed to fit a cossie T3 onto escort exhaust?
Old 30-08-2011, 09:39 AM
Joe91
Joe91's Avatar
Default What's needed to fit a cossie T3 onto escort exhaust?
ive been told that the exhaust housing side of the turbo doesn't fit onto the exhaust of the S2, is it a case of fitting a escort housing or do I need other parts?
I expect this thread has been made a couple of times but I'm on my phone and can't look for them, if there's a thread on it then just a link will do..
Thanks, Joe.
Old 30-08-2011, 09:57 AM
Rob_DOHC
Rob_DOHC's Avatar
I think (although i've never done it) you need a cosworth exhaust elbow and a new down pipe.
Rob,
Old 30-08-2011, 10:44 AM
raycov
raycov's Avatar
the down pipes you wont i have to fit a 4 inch exhaust though
Old 30-08-2011, 10:47 AM
Rob_DOHC
Rob_DOHC's Avatar
Wow thats pretty big...
Old 30-08-2011, 12:25 PM
raycov
raycov's Avatar
i had the down pipes profresionly made i fitted it to t35 with a maram shaft but when i fitted it all it was miles to laggy so i have gone back to my t3 stage 3 hybred that why the part are for sale i also fitted a mongoose 4 inch stainless steel all the way through thats why the down pipe is 4 inch
Old 30-08-2011, 12:26 PM
Joe91
Joe91's Avatar
I Didn't think they had elbows? I take it you cant just put a exhaust housing/elbow off a S2 T3?
Joe
Old 30-08-2011, 02:39 PM
raycov
raycov's Avatar
no not a a cossie t3
Old 30-08-2011, 02:55 PM
russ rs
russ rs's Avatar
surely you mean a 3inch system with 4 inch tail pipe
Old 30-08-2011, 03:00 PM
raycov
raycov's Avatar
i just ckecked the bore size and its a 3 inch pipe sorry about that lads
Old 30-08-2011, 03:40 PM
rsmark86
rsmark86's Avatar
give someone like oddkidd a ring mate, you have to cut the top off the escort down pipe along with the cossie one and weld them together, so best to get a pro mate
Old 30-08-2011, 04:18 PM
Joe91
Joe91's Avatar
Mmm seems like to much hassel really..Think ill stick with a T3 stage 3 hybrid or T34, only thing is there isnt many around at the moment, i can only find 1 T3 hybrid!
Joe
Old 30-08-2011, 04:29 PM
muz
Wye Valley Hardcore
muz's Avatar
You get get a .48 housing which fits exactly the saem as the ERST elbow and fits perfectly to the RST exhaust system. Over 250 BHP (or so I'm told) the standard elbow is restrictive. All you need to do it make a downpipe. It's not difficult if you have a welder. I made a 3inch downpipe to fit the tubular manifold and T34 with a cossie ex housing out of a cossie downpipe and a flexi joint to act as a stepper from the 3" downpipe onto the 2.5" Mongoose exhaust.
Two together
Cut an tacked together
All welded up
Fitted
Hope this helps.
Old 30-08-2011, 04:53 PM
rsmark86
rsmark86's Avatar
Send your turbo off to cr turbos and they will build yours into a stage 3 hybrid for less than £500 with all postage then you have a brand new unit , good for 250bhp+
Don't bother with a stage 1 they are no better than standard.
Old 31-08-2011, 02:46 PM
Canada1
Canada1's Avatar
Yikes!!
How do you UK guys build cars over there? The parts costs are silly.
A new T3/T4E .58 45 trim (350 hp rating) is $700.00 (432 pounds) here in Canada.
Rs_Motion
Escort MK 5 / MK 6
43
27-12-2018 11:49 AM
RsS2daz
14-08-2015 05:26 AM
track.focus'd
12-08-2015 05:53 PM
col93saphcos
07-08-2015 03:21 PM
Old ford
31-07-2015 06:50 AM
Quick Reply: What's needed to fit a cossie T3 onto escort exhaust?
