Cylinder Head Core Plug
What is the best/easiest way to remove the core plug in the cylinder head?mine i leaking very slightly i know they are pressed in its just getting old one out.
Cheers Ben
Cheers Ben
Its the one above the gearbox, as i was cehcking over the engine bay saw some coolant marks and followed them back to the core plug weeping a little,the plug itself is only £2 from ford its just getting old one out without makin more work for myself.
Cheers Ben
Cheers Ben
One of the little ones?
You could drill a hole in the centre, and use a slide hammer to pull it out.... or screw a self tapper in there and use that.
I would probably use a self tapper and a pair of pliers, then knock one side of the plug in (tilting the opposite side out), as soon as you've done that you've won.
Installing the new one is as simple as drifting it in.
Good luck
Rob,
Good luck
Rob,
massivewangers
30
01-10-2015 07:40 PM
wheelwizardrefurbs
18-09-2015 08:59 PM
