where can i buy this seal/ gasket? pics included IS MY TURBO SCRAP?
as title the oil is leaking i need to know where to buy a new gasket cheers
the joint right at the end of my finger
the view from below
one thing after another with this car
any help greatly appreciated
the view from below
Last edited by bubs_rsturbo; 31-08-2011 at 04:01 PM. Reason: possible turbo failure
if u mean a gasket for bwteen the turbo elbow and housing, there isnt 1
if its pissing oil out of the turbo, im no expert but id say turbo seals gone? so rebuild time?
cheeRS
i have managed to get a second hand one at a good price as i am not working at the minute, then the plan is to get my old turbo sent off to get rebuilt to stage 2 when i can find a job!!
the car already has a brand new gasket for where the manifold meets the engine, so if i dont need a gasket for manifold to turbo, and dont need one for turbo to elbow then the only one i need is for the downpipe?
you do need one for manifold to turbo neil, you wont need one for elbow to downpipe tho, check out the burton power website as they list them
you dont need any gaskets other than exhaust manifold to head gasket,the long 4 port one.
no gaskets needed on the manifold to turbo,turbo itself,or exhaust downpipe mate
if the mating surfaces are flat then you wont need a gasket mate.
put a straight edge across them and see if there flat,if not you could skim them or use a copper gasket.
only gasket you can get i think is the turbo to manifold one,square with 4 holes for the bolts and square hole in the middle i think.
they are about £12 on fleebay.
bassboy
08-08-2015 10:21 AM
