rst wont start
Old 16-08-2011 | 10:26 AM
russ rs's Avatar
russ rs
Default rst wont start
ho guys after not starting car after putting new ap clucth in and stage 3 turbo. Has been sat for 2 months. I have fuel and 13 volts and still wont start i have also tried pushing down the flap in metre unit, thanks for help
Old 16-08-2011 | 12:05 PM
series_one_rst's Avatar
series_one_rst
make sure there`s no air leaks, you got a spark? what else have you looked at?
Old 16-08-2011 | 12:44 PM
russ rs's Avatar
russ rs
All plugs sparking and fuel into metre unit. I will check boost pipes tonight.
Old 16-08-2011 | 12:58 PM
martysmartie's Avatar
martysmartie
Check all connections, after the work you most likely have a stray connector etc.
Martin
Old 16-08-2011 | 01:21 PM
series_one_rst
vacuum pipes breathers boost pipes everything. temperamental bleeders the mfi system.
Old 16-08-2011 | 01:35 PM
russ rs's Avatar
russ rs
Yea ok thanks I check later then update once at unit
Old 19-08-2011 | 07:24 PM
russ rs's Avatar
russ rs
Well it's got spark pipes are tight and got fuel funny squealing coming from meter side though
Old 19-08-2011 | 08:24 PM
MO' BENT RIMS's Avatar
MO' BENT RIMS
try new metering unit bud
Old 02-09-2011 | 08:30 PM
russ rs's Avatar
russ rs
Still no joy turns but no fire got spark an fuel and I push down flap in meter unit surely should turn over once or miss
Old 02-09-2011 | 09:06 PM
russ rs's Avatar
russ rs
How can I check meter unit???? Makes a strange noise coming from back of it
Old 02-09-2011 | 11:17 PM
MO' BENT RIMS
try a different one
Old 03-09-2011 | 08:48 AM
milesy23rst's Avatar
milesy23rst
PUG 306 GTI-6
Sounds like your metering unit has had it or the black empfa unit on the side of it
Old 03-09-2011 | 02:24 PM
russ rs's Avatar
russ rs
That what thought any way of testing it?? I only want us it couple days before strip for zetec lol
Old 03-09-2011 | 02:50 PM
Scott_Rst's Avatar
Scott_Rst
When i put my old engine in my car the metering unit also made a squealing kinda sound, was getting some fuel through the system,but spent a while cracking all the fuel pipes on unit starting with main feed then pipes on the injectors, and then she fired up
Old 04-09-2011 | 07:43 PM
russ rs's Avatar
russ rs
sorry mate cracking pipes???
Old 04-09-2011 | 10:59 PM
Scott_Rst's Avatar
Scott_Rst
By cracking i mean loosening the banjo bolts that hold pipes onto metering unit (individually),, then once theres plenty fuel coming out from them do the same to the pipes on the injectors,, i had a mate in the car flicking the ignition on when id "cracked" a line to prime pump and push fuel through,, worked for me anyway mate,but you might have another issue? Good luck!!
Old 05-09-2011 | 06:42 PM
russ rs's Avatar
russ rs
I give it a try mate
Old 09-09-2011 | 09:16 PM
russ rs's Avatar
russ rs
What's the wires for on left hand side o meter unit should it have power with ignition on??
Old 30-08-2013 | 10:54 AM
Richard666's Avatar
Richard666
If u put ignition on then push mfi flap down u will get a squeal noise that is pushing fuel to injectors then once uv pushed it couple times try turning it over it should start
Mine does the same when left for couple days but once I've had it running it starts every time after that
Old 30-08-2013 | 03:24 PM
Fordmad!'s Avatar
Fordmad!
This is a 2 year old post
Old 30-08-2013 | 04:52 PM
Richard666's Avatar
Richard666
I realised just as I posted a reply lol well I might help someone lol
Rob Wells
Ford Mondeo Including ST
18-04-2023 12:19 AM
JK12
33
26-04-2021 12:09 PM
xrmalin
13-09-2015 06:52 PM
andrewmctiernan
08-09-2015 03:05 PM
stevierob
07-09-2015 07:09 PM
Quick Reply: rst wont start
