my fuel pump prime sounds weak/non runnin rs
cant get my car 2 start, bin off the road 10 months, no fuel getting to the injectors but everywere else, my pump doesnt prime nice an loud like it use 2, so i bought another 2cd hand one, an it sounds exactly the same weak, do u think i hav a faulty wire causing this? cheers
i havnt took the injectors out yet, iv had the 4 injector pipes off at metering unit an pressed flap whilst its bein cranked but it trickles out, an doesnt hav enuff pressure to go up the line to the injector, might i have a airlock ? if so how do i check/fix cheers
at the back of the pump there is a non return valve valve that sticks, this happened to me, i changed many pumps but not the valve so may be worth a try.
Cheers PaulT
Cheers PaulT
nope i havnt changed it as i fort it was working ok cause the pump is priming, would it still prime with a faulty fuel pump relay?
JK12
33
26-04-2021 12:09 PM
jonfoc
16
11-09-2018 05:35 PM
