brake problem
Jun 15, 2008 | 02:46 PM
brake problem
took the abs off the series 2. put left the pumps on there. but the brakes are shit now they are all bleed properly. any ideas do i have to change the master cylinder?
Jun 15, 2008 | 03:07 PM
have u just snipped the belts or removed it compleatly??did u bleed the brakes with load on the rears????
Jun 15, 2008 | 03:10 PM
what we done was took the pipes out the resivour and bypassed them if you know what i mean. no didnt bleed them with load on the rears.
Jun 15, 2008 | 04:05 PM
need to snip the belts and load needs to be on the rears for the load bias valves!
Jun 15, 2008 | 04:17 PM
you havent taken the abs off then!! the only way is to remove the modulators totally and replumb the brake lines
Jun 15, 2008 | 04:19 PM
if i snip the belts and put the pipes back in the resivour will this be ok?
Jun 15, 2008 | 05:17 PM
ideally u need to loose the whole abs crap,its pretty easy to re pipe it,ive just snipped belts and been fine,but if the pumps are faulty it can effect how the brakes work
Jun 16, 2008 | 03:18 PM
is there a way that you need to bleed the brakes with the abs?
Jun 16, 2008 | 03:22 PM
do i need a non abs master cylinder and servo to remove the abs to make it work properly?
yatta
May 21, 2016 10:31 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
focus2351
Sep 9, 2015 09:33 PM
routemaster
Sep 7, 2015 05:27 PM
cossirob
Sep 3, 2015 09:17 PM
