S2 fuel pump (pink?) relay
I take it, you still have your old one but it's not working properly?
Usually it's possible to repair them. Pull the cap off and resolder the joints. That should do the job.
Hi guys, the ebay dude won't send to Israel...can any of you do me a favor and buy from him and send to Israel? I tried to fix it and it works for the moment , but I can't rely on it that way....
If any of you willing to buy and end to me, It would be great...
You have to ask your self why its went also.
It could be just that it is old.
or usually the fuel pump starts to deteriorate drawing more current from the battery, heating the relay up, drying it out and the solder cracks. once its been running for a bit, feel if the relay/wiring is warm!
if so the pump is probably on its way out.
Im sure its possible to rewire it for another type of relay, something more readily available and better designed!
Hi mate!!
Try this:
http://cgi.ebay.co.uk/FORD-ESCORT-RS...QQcmdZViewItem
http://cgi.ebay.co.uk/FORD-ESCORT-RS...2em118Q2el1247
Hope this will help you.
Try this:
-----------£35 for a f-------relay thats bollocks-----------------if you buy that get them or someone to look at your head as well!!!!!!!------THESE ARE NOTHING SPECIAL AS EVERY ONE THINKS------TAKE YOUR OLD ONE TO AN AUTO ELECTRICAL SHOP////EG--MIDLAND MAGNETO IN NOTTS!!! YOU KNOW WHY ITS PINK DONT YOU???? SO YOU CAN SEE ITS A FUEL ONE AS AGAINST THE REST-------------------------------IF THEY WAS ALL THE SAME THEY WOULD ALL BE FUELS PUMP ONES _LOL
LOOK AT THE CONTACT TABS ON THE OUTSIDE/PLUG AND COMPARE THEM WITH OTHERS
JK12
33
26-04-2021 12:09 PM
155lee
24-10-2015 11:11 AM
