tyre sizes again !!
Old 23-06-2008, 06:51 AM
bluescortcossie
bluescortcossie's Avatar
Default tyre sizes again !!
i have bought some wheels of the bay (16" mondy 5 spokes) but they are fitted with 205/55/16 tyres , 2 of which are new and 2 hardly worn so ideally want to keep them but am i going to get any rubbing issues ??
bear in mind its a 2dr estate that lowered 60mm !!! but ......... i got 205/40/17's on it with NO issues other than slightly rubbing on full lock
is there much difference in the overall size of the 2 tyres ?
opinions please and i haven't picked up the wheels yet before someone says just try them
Old 23-06-2008, 10:18 AM
antony215
Escort Rs Turbo
antony215's Avatar
You may well get slight rubbing with a 55 all depends on the offset of the wheel.
Old 23-06-2008, 10:47 AM
Rab
Fucking superstar........
Rab's Avatar
Slight rubbing issues???
Those tyres are huge!!!
Old 23-06-2008, 10:53 AM
Rab
Rab's Avatar
Overall diameter is 647.9mm for a 205/55/16
Overall diameter is 612.8mm for a 205/40/17
Standard overall diameter is 591mm for the 195/50/15
So, you'd be going waaaaaaay over with a 205/55/16. My Avensis uses this size of tyre, and they're HUGE!
Old 06-07-2008, 05:04 AM
oohogwash1
oohogwash1's Avatar
These are great size information bits Rab,
I am setting up my suspension on my 3dr project but dont have any wheels / tyres for some time.
Do you know any more overall diameters ? especially for 17 / 18s with different profile tyres.
I am thinking 18" rims as wide as possible will be the rim I will go with. I am trimming 10mm of the wheel arch to allow wider tyres , lowering with coil overs and modifying the trailing arms to be adjustable so I get the right camber, toe in... I know what ride height I desire...
Any help you can give much appreciated...
I need some idea of tyre diameters to know what range of adjustment I will need and where to locate the centre of adjustment.
Old 06-07-2008, 12:47 PM
oohogwash1
oohogwash1's Avatar
I found a forumlae to calculate overall height, interestingly enough each figure it calculates is 16mm less than your figures... I checked against the tyres on cars here and it seems correct...
the calc is diam*25.42 + 2*aspect/100*width
Mark RS
05-03-2021 06:08 PM
tankybaby66
06-02-2016 02:24 PM
07-10-2015 12:56 PM
M7 COS
Wheels and Tyres
01-10-2015 04:46 PM
Alloy wheels and ICE for sale
28-09-2015 06:19 PM
Quick Reply: tyre sizes again !!
