What power how much boost
Hi ive recently finished my series one, done a bit to the engine, was just wondering what boost i should be running with my spec and what sort of power it will be when set up spec as follows.
1.9 american tall block cvh
stage 3 head
kent cam with vernier
cone filter
group a coil
chipped ecu
full scorpion exhaust
erl fith injector
turbo unknown hybrid
full front mount intercooler with twin fans
stage 3 head
cone filter
group a coil
chipped ecu
erl fith injector
Colossal Pervert
14psi on a 1.6 and 14psi on a 1.9 aren't the same thing.
I think 1 bar will be about your limit, from what i've seen. You'll either start to run lean or if you have a great metering head, you'll be close to the limit of your rods (if the turbo flows enough).
well my heavily modded 1.8 runs 18 psi with no bother at all and has been doin so for over 4 years now!!
Mark RS
12-10-2015 06:01 AM
Russ Payne
25-09-2015 08:29 PM
