swopping gearbox casings
Old 10-06-2008, 08:49 PM
cressy
cressy's Avatar
Default swopping gearbox casings
any one know ruffie how long it takes to swop the inturnals of a series2 box into a series1 please?
Old 10-06-2008, 09:08 PM
MarkXr
MarkXr's Avatar
Depends on how familiar you are with gearboxes and if the 5th gear comes of easily or not.
If you haven't done it before, let someone show you who knows what he/she is doing.
Can be done in a couple of hours providing that the 5th gear doesn't stick on very bad.
Old 10-06-2008, 10:15 PM
markyrst
markyrst's Avatar
my brother just done mine for me. didnt take too long. box was out, stripped, built and fitted again on a saturday. 5th gear is a bollocks though
Old 10-06-2008, 11:43 PM
antony215
Escort Rs Turbo
antony215's Avatar
If you just want to you can swap just the middle casing (the mount bit on the s1 case) job done. As said 5th gear is a fucker to get off tho.
Old 11-06-2008, 06:11 PM
Moonie
Moonie's Avatar
Have a look at my rebuild thread which will show you what to expect inside the gearbox (rebuild pics near the bottom of the page).
https://passionford.com/forum/restorations-rebuilds-and-projects/196934-engine-and-gearbox-rebuild-time-update-24-08-a.html
You will proably need a decent puller to remove the 5th gear and apart from that its quite straight forward. If you just want to swap over the case for the series one engine mount then you can leave the shafts and selector mechanism in the lower gearbox casing.
You can get a gasket set from here...
http://www.maintrainltd.com/
One thing to remember is take note of the direction of the slot in the end of the 5th/reverse gear selector rod. When you are rebuilding the box and fitting the 5th gear selector you will have to turn the selector rod clockwise before tightning the pinch bolt. If you dont turn it you will have no 5th or reverse gear or no gears at all as it will jam the selector mechanism.
Old 12-06-2008, 01:09 PM
Aaroncast
Aaroncast's Avatar
Talking
Ive Heard Somewhere The 5th Gear Can Be A Bitch!!!!!! Lol-yahooooooooooo
Old 20-06-2008, 09:28 AM
steven botes
steven botes's Avatar
fifth gear can be an absolute C*&T!!
i use a puller that has two wide flat legs that go around both sides of the gear , and two 8" g glamp that i hold the legs together with. With a buddy holding the g clamp and bracing himself , i use an electric impact wrench and much swearing
Old 20-06-2008, 09:55 AM
cressy
cressy's Avatar
not bothering now buying a new box just seems a lot easyier lol
chowfornow
14
05-01-2019 09:01 PM
mjonathan24
29-10-2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
17-10-2015 10:32 PM
Iain Mac
30-09-2015 09:39 PM
muz
30-09-2015 08:29 AM
Quick Reply: swopping gearbox casings
