fifth injector
is it possible to acheive a genuine power figure in excess of 240 bhp at the wheels using a fifth injector? only asking as i'm considering useing one until i have the money to upgrade to a proper management system. also where can i purchase a fifth injetor setup and get it properly set up?
cheers
tom
cheers
tom
Bodybuilding
Location: Cannot be identified by the information given.
MFi does NOT restrict power output its just a difficult system to setup to fuel properly at high boost EFi is just alot easier more refined setup
Tim made 288 bhp @ 21psi NMS 1.6 cvh with a MF2 5th injector
![](http://homepage.ntlworld.com/tim.butcher/newgraph.jpg)
Yes it can be. Wiring is quite simple. You will need a a cossie map sensor (3bar) and an injector (cossie green or grey for example)
You then need a boss to allow mounting of the injector to the crossover - such as an 8v astra gte item..
i think you will pay about 350 for the kit but then add cost for:
installing injector into your standard crossover pipe
injector
wiring unit in
mapping
injector
wiring unit in
mapping
mk3ste
17-10-2021 10:09 AM
DixieTheKid
11
06-06-2020 11:20 AM
