What connects here? MFI picture identification,this right?
Project Money Pit
can some helpful people help me finish plumbing in my RST conversion
i have these three small unions to connect up
the air hose to the actuator and the union on the turbo housing - both seen in this pic
and this pipe on the metering head
do they connect to the amal valve? i don't think i have one what does it look like.
could someone also have a look at these and check theres nothing glaringly obvious wrong
It Wasnt Me!
If you have no amal valve, block the one on the metering unit up and conect the actuator - compressor housing on the turbo, it will boost to whatever the actuator is set too so obviously you'll need to adjust the actuator to suit the boost you need!
get it on a RR when you get it running anyway imo
Project Money Pit
yeah will take it to an RR - should i connect the bleed valve inline with the actuator/turbo so i can manually set the boost limit?
thanks for your quick reply
Don't mention ze Vor
It Wasnt Me!
tbh i'd leave the bleed valve off as it can only increase boost not lower it from what the actuator is set too.
the tuner will add it in if neceser, jus stick it in the glovy for him
Mark RS
12-10-2015 06:01 AM
