bleed valve
ok been a while since last had rst just got my new one and im sure they have put the bleed valve on wrong all it is is of the turbo then bleed valve then actuator and the bottom bit that is supposed to go to the metering unit is not even there so gona have to connect it is that wright
ok i will make it easier for you the piping for my bleed valve goes like this.
pipe from the turbo then goes to one side off the bleed valve then out the other side to the actuator and nothing coming out of the bottom. so i need to connect the bottom bit of the bleed valve to the metering unit hope that makes it easier
