rs turbo ecu
Originally Posted by swerv
do rs turbo ecus have fault codes damn never knew that
i thought if it runs it works
RST's will run with no fuel ECU....admittedly like a pile of shit but they will do it, they operate like K-Jetronic when something on the fuel management fails.
PeterRST thats the ignition ECU not the fuel one
Mulla,
Which ecu are you refering to? Nobody said fuel ecu but Safechav.
its the one behind the heater blower,when i start her up she starts for one second then stops,keeps doing that when it starts up black smoke comes out if i turn her off and try again it wont start keeps doing that,before this happend it sounded like it was fireing on three cylinders,it gradually got worse i changed the plugs as they were black,changed leads but still same problem just does not fire up,so i think its the ecu or metering unit any help please.
Ahhhh sorry im sure i read fuel ECU
And jesse you are right i know K is a bit more complicated then KE without an ECU, hence why KE wont start well from cold when the management fails
just stripped the metering unit down just in case looked alright .i put it back on the car but did not put the injection pipes back on fuel came out of the coldstart hole so fastened that back on but on the injectors fuel only came out of one what do you think.
big_Rad
15-09-2017 09:36 AM
Matt Baxter
16-09-2015 08:30 PM
