s1 turbo fuel pump priming problem?
when i turn ignition on fuel pump primes as it should, then when i turn wipers on it primes again and also when i turn lights on, although does not do it with lights everytime, that is without the engine running, have also changed the wiring loom, fuel pump, fuel pump relay, please help cheeRS
A common thing on the S1's, they have a different relay to all the other MFI cars, i think they are just a bit sensitive to voltage spikes, nothing to worry about
Mine re primes when you put the side lights on. If it's running ok just ignore it. If you start to try and solve it, you could open a can of worms
Originally Posted by J690Turbo
do have other problems too, took it to be set up and the guy said theres no power goin to the engine sensors wot eva he means by that
That sounds like a matching excuse for someone that doesn't know/cant be bothered.
Care to mention any names or not?
If you can you want to get it to one of the tuners on here like Stu/Christian/Norris etc, no bullshit that way
Originally Posted by rs shawn
Did you not think to ask ??
Bit of brown sauce on them and some bread and butter and it's a feast
kosienutter
31
22-08-2015 09:55 AM
CabrioTurbo
01-08-2015 11:04 AM
