Fuel Pump Relay Issue
Old 30-04-2007 | 08:36 PM
BlueFiesta85's Avatar
BlueFiesta85
Default Fuel Pump Relay Issue
need some help with this, cant figure out what it may be ive tried everything.
well connected up all wires and relays correctly came to start the engine and there was no noise for the fuel pump priming (new bosch pump fitted), all wires are connected properly as ive checked the pump manually.
the car turns but it does not start, there is fuel coming at the metering unit as i unscrewed the pipe to check it.
my main concern is ive changed the relay around with a different one (same type but from another car) and on ignition it does not prime like it should do.
can someone please shed some light as i spent a good three hours trying to sort it out with no joy
Old 01-05-2007 | 07:35 AM
idanrs's Avatar
idanrs
I think i can...
that is a difficult one, only thing i can thing of (kind of stupid)
if you say that all the wires are in place for 100% and the pump and relay are working a 100% the try to over pass the relay, open the fuse box and wire the wires between the relay and directly to the wires of the pump...
i suggest you have an electrician on standby...
good luck and plz post results...
Old 01-05-2007 | 07:52 AM
RobL's Avatar
RobL
ive got a similar problem with mine at the minute
when i turn the ingnition the fuel pump dont come on ,ive tried a wire from the battery to the pump and the pump works
am i in need of an auto electrician?
is there any way of knowing the relay is no good or i do i just try another one?
sorry to hijack your post fella just seems a bift daft to have two topics concerning same thing
Old 01-05-2007 | 08:33 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Could the relay be fucked? ive jus tried a diff one in mine and it primes but doesnt fuel when cranking so doesnt start! yours could be the opposite?
Old 01-05-2007 | 08:39 AM
BlueFiesta85
ive tried two different relays and had no luck, would it have anything to do with the ecu and maybe the new fuel pump?
Old 01-05-2007 | 08:44 AM
vroooom ptssssh
It Wasnt Me!
Doubt it, the fuel relay controls the prime...if its the pink/purple S2 relays then I wouldnt be surprised if both are fucked....
Old 01-05-2007 | 09:12 AM
BlueFiesta85
when the key is turned (before starting) does the power go directly to the relay and then the pump, im thinking if there could be a fault in the circuit somewhere. this may sound a bit weird but when i took the relay out with the key in position 0, and put the relay back in half way the pump primed, pushed it in all the way and then turned the key but no noise from pump. what could this indicate?
Old 01-05-2007 | 09:31 AM
vroooom ptssssh
It Wasnt Me!
Sorry mate its beyond my knowledge now, give SafeChav a pm he's the sparky boffin!
Old 01-05-2007 | 11:03 AM
BlueFiesta85
ok gets even weirder now and annoying when the keys are taken out the ignition, the lights on dash are on (battery etc) you can operate the fan and everything else thats works WHEN the only the keys are in and 2 turns of the key.
have i connected the wires to the battery incorrectly you think? theres the thick black one that gose to negative, then i have about 7 other wires goin to the positive (three brown ones, two black ones, two other black ones for the alarm and the thick red starter wire) i got a gut feeling that these wires are connected up wrong
Old 01-05-2007 | 01:31 PM
SafeChav's Avatar
SafeChav
Right........what have you done to the fuel pump relay wiring and why.
Straight away from what you're saying about the dash lights i can tell you that you've wired something wrong and its back-feeding the ignition circuits...........
Old 01-05-2007 | 01:32 PM
SafeChav's Avatar
SafeChav
Just noticed aswell you've connected those browns to the +, you may well have caused some damage there
Old 01-05-2007 | 07:34 PM
BlueFiesta85
yes mate that was the cause of a whole days worth of swapped the wires around and sorted the problem out, both relays were fine in this case, just put the wiring the wrong way around on battery, clever me hay lol. everything seems to be fine, apart from the idle of the car is rough and lumpy, but thats prob due the actuator i changed. need to have it checked and tuned now.
thanks for the help guys
Old 01-05-2007 | 10:58 PM
SafeChav's Avatar
SafeChav
an actuator should never ever ever make any difference to how a car idles.....
Old 02-05-2007 | 07:31 AM
gambit's Avatar
gambit
Default fuel pump
you've fowled up the plugs (flooded the engine) whilst trying to start it for 2 days with the battery terminals on the wrong way
oh well at least it was a cheap fix and no other problems occured due to this, well done for finding the mistake and best of luck with getting it running good mate. Check all your fuses etc. are still o.k
Old 02-05-2007 | 02:42 PM
SafeChav's Avatar
SafeChav
The plugs should soon clear up with a bit of warmth in the engine though!
I doubt its that, probably missed a pipe off somewhere and have a small airleak.
Old 02-05-2007 | 07:24 PM
BlueFiesta85
i checked the plugs and noticed that there quite wet (ovefuelling i assume) i am going to take the car to be tuned due to new actuator and fuel pump fitted, but im a bit worried whilst driving it with the plugs wet like that and hestitation on acceleration i may well just **** the engine up. excuse my french. any ideas?
Old 02-05-2007 | 10:01 PM
SafeChav's Avatar
SafeChav
Have you had the engine up to operating temperature since?
Old 03-05-2007 | 06:01 AM
gambit's Avatar
gambit
Default fuel pump
yes matey your best bet is get a tune up
Old 03-05-2007 | 08:34 AM
BlueFiesta85
safechav yes i let it run for 20 mins but stil they were wet
gambit gez i need to make sure it doesnt mess up the engine before i get it their
ive turned the boost right down, but when giving it some gas its quite hesitant and sometimes even stalls if i dont give it enough, mayb its an idea just to have it towed or trailered down
Old 03-05-2007 | 12:03 PM
SafeChav's Avatar
SafeChav
Very wierd. I cant help but think maybe you've damaged your fuelling ecu by connecting that wire wrong.
What happens if you pull the plug off for the EMFPA when its idling?
Rob Wells
Ford Mondeo Including ST
18-04-2023 12:19 AM
JK12
33
26-04-2021 12:09 PM
Prickly_buzz
25-08-2015 11:33 AM
kosienutter
31
22-08-2015 09:55 AM
CabrioTurbo
01-08-2015 11:04 AM
Quick Reply: Fuel Pump Relay Issue
