s1 gear linkage
01-05-2007, 10:00 PM
burning oil
s1 gear linkage
hi all can anybody tell me where i can get a new gear linkage for my s1 turbo its a bit on the sloppy side and 3rd is a bitch sometimes so wanted to do somethin about it
01-05-2007, 11:22 PM
Get the bits and service it, its only worn parts making it sloppy.
Doubt very much if you'll find a new linkage easily
02-05-2007, 11:56 AM
It Wasnt Me!
Can you get a service kit for it? what about the actual selector on the gearbox the linkage connects too? think mines a bit worn.
02-05-2007, 01:03 PM
get a b&m quickshift it improves the gearchange no end u will need to use ur old selctor and stabilser rod though as they dont come with them and are no longer avalible from ford the b&m is about £215
02-05-2007, 02:49 PM
The selector in the box will never wear to that extent, its always the linkage trust me.
02-05-2007, 03:10 PM
Quote:
From experience I don't trush you. The stick, casing bottom, casing top cover, etc. are usually extreamly worn and beyond repair. As a bonus, some parts cost so much that one can buy two new complete Puma shifters for the price of the replacement parts.
02-05-2007, 08:22 PM
Whack the U/J with a hammer to tighten it down a bit.
If its worn shim it with washers then whack it lol
02-05-2007, 09:50 PM
i just got a new selector with the u/j on it from ford in kirkcaldy cant mind how much it was that much
02-05-2007, 10:12 PM
02-05-2007, 10:18 PM
meant to say it was for a s2 tho dont know if it makes much odds
02-05-2007, 10:23 PM
All the same
02-05-2007, 11:25 PM
Internals are different
S1 has the 'gate' in the bottom of the plastic bit
02-05-2007, 11:26 PM
yea i just meant the same on all Mk4's and the same on all Mk3's
02-05-2007, 11:39 PM
Same - but different
03-05-2007, 12:20 AM
08-05-2007, 11:51 AM
i bought the gear stick & bushes from ford 18 months ago. cost me about £50 for the stick & pennies for the bushes. Could be worth a try
tankybaby66
06-02-2016 02:24 PM
07-10-2015 12:56 PM
The Youth.
30-09-2015 09:59 PM
dojj
29-09-2015 10:32 PM
cameron2
23-09-2015 06:31 PM
