S2 HELP needed with anoying problem
Old May 13, 2007 | 10:53 AM
Red Van Man's Avatar
Red Van Man
Default S2 HELP needed with anoying problem
It all started a few weeks ago when my car seemed to hesitate a little when warmed up, but only intermitently. After a week of this it died on the way to work. AA towed me home and told me it was the distributor. Brand new distributor and still same problem. Also changed plugs, leads, cap, rotor arm, coil and tried another ecu. When cold it starts fine and runs perfectly, but only whilst stood still. As soon as the engine is put under load it dies. I'm no expert and would welcome any help at all.
Car spec;
88 Escort Combi
90 S2 engine
K+N, Magnex, Samcos, Pace i/cooler, Turbosystems chip,KV85 leads, Champion QC plugs, Gpa coil.
Old May 13, 2007 | 07:59 PM
johnnysash's Avatar
johnnysash
sounds like fuel and as the cold start keeps it running.... could be the metering head? could be a weak pump? check for air leaks as well? failing that push it round the corner and get the aa to check it again...... "Fix this by the roadside aa man!!" ha ha!
Old May 13, 2007 | 09:35 PM
Barry R's Avatar
Barry R
failing that push it round the corner and get the aa to check it again...... "Fix this by the roadside aa man!!" ha ha![/quote]
i second that
Old May 13, 2007 | 10:49 PM
SafeChav's Avatar
SafeChav
you got a dump valve by any chance?
Old May 13, 2007 | 11:23 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Mins been missfiring once right up to temp (half way on the guage), need to change my plug leads to eliminate them
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
col93saphcos
Aug 7, 2015 03:21 PM
