oil pressure switch and speed sensor for an efi conversion
Iv been connecting up my new ecu loom and i was wondering if the speed sensor and oil presure switch is diffrent on the efi setup? The speed sensor seems to have a diffrent plug and i was wondeing if the oil pressure swich is diffrent as the connector doesnt fit on the end Do i need the efi ones?
Oil pressure switch is the same the plug should fit
Speed sensor plug is different but is the same thing inside. I can sell you a proper jobby with the correct plug if it bothers you though
mrmann
20-08-2015 11:24 PM
