S2 RUNNING HOT WITH PRO ALOY COOLER FITTED????
Old 14-10-2005 | 11:26 AM
320 bhp's Avatar
320 bhp
Default S2 RUNNING HOT WITH PRO ALOY COOLER FITTED????
CAR RUNS COOL WHEN ON THE ROAD BUT AS SOON AS IM IN TRAFFIC THE TEMP GAUGE GOES TO THE RED ANY IDEARS CHEERS
Old 14-10-2005 | 11:30 AM
CliffRS4's Avatar
CliffRS4
The intercooler is blocking the flow of air to the radiator so less cool air is getting to it.
Do you have 2 fans?
I have a GRS Intercooler on mine and I removed the thermostat from the thermostat housing too. Get an over ride fan switch wired up like I did.
You can turn the fan on whenever you get into traffic to keep the temps down
Old 14-10-2005 | 11:35 AM
320 bhp's Avatar
320 bhp
YEH HAVE 2 FANS WILL REMOVE STAT AND WIRE FANS UP AND TRY IT
Old 14-10-2005 | 01:38 PM
GrimmeRS2K's Avatar
GrimmeRS2K
u have the fans spinning the wrong way, change the wires around the other way it will be fine, the fans will suck rather than blow, a common mistake when installing a FMIC with 2 fans!
Old 14-10-2005 | 02:36 PM
Rick's Avatar
Rick
Bad idea. They are there for a reason. If you don't want a stat for some reason, use a restrictor.
Old 14-10-2005 | 03:41 PM
adamS2RST's Avatar
adamS2RST
As above...
Old 14-10-2005 | 06:04 PM
Davey8oy's Avatar
Davey8oy
Rick
adamS2RST
true! it causes cyl no 4 to heat up! i took the centre out my thermostate! it causes a slight restriction in water flow but helps it to run cooler!
Old 14-10-2005 | 06:39 PM
mark-rst's Avatar
mark-rst
I got a Gen 2 Pro Alloy
found that i had to put a 82c stat in and a cossy 4wd cooling fan switch
also had to butcher the bumper for decent airflow into it as well
It runs under 90c all day long now
kosienutter
31
22-08-2015 10:55 AM
track.focus'd
12-08-2015 06:53 PM
Red_bull
09-08-2015 09:34 AM
Caddyshack
15
04-08-2015 09:50 AM
fish6634
Ford KA
02-08-2015 02:02 PM
Quick Reply: S2 RUNNING HOT WITH PRO ALOY COOLER FITTED????
