ABS Pipes
ABS Pipes
Does anyone know where i may be able to get the flexi pipes from that connect the ABS pumps to the block below them. Someone has held one of mine together with a jubilee click as i found out under hard braking over the weekend
I've tried Ford and pattern but are no longer available off the shelf...
Found one on here, £9.40 delivered!
http://www.partsgateway.co.uk
Might be of use for other parts too as it sends your request to a few breakers
Don't mess around with flexibles. Go to your local quality motorfactors (Clarkins in Leyton or Walthamstow make them while you wait) and get proper copper ones made up. Cost about a tenner with the fittings included.
Hope this helps. Luv n huggs The Dr
