zetec turbo compession ratio
Can anyone add to this before i bolt it together? if you have experiance building 1, pay attention to the pistons i fitted & does this seem right? (last paragraph, first post)
http://www.fiestaturbo.com/phpBB/viewtopic.php?t=114741
thanks steve
thanks steve
Hello Mate
Check out,- www.turbofast.com.au/Tfcomp.html to calculate your C/R
Not sure what head you're using if it's an Rs T remember your head volume is about
57 cc and a typical Felpro head gasket is 1mm (0.040 thou) thick.
Hope this helps
Luv n Huggs
The DR
Hope this helps
Luv n Huggs
The DR
