Hi,im looking into buyin koni's and have been told i should only lower my rs turbo 25mm - 30mm and was woundering what you lot here think and also i would like to see some pictures of your cars lowered 25mm or 30mm on 17's.
i like ur combi mate ive got system 2 shocks on there at the mo which are not bad but would rather koni's,any had system 2 shocks too?what did you think of them?
i got a set of heavy duty caravan springs in the rear of mine just cut them so same hight as 30 drop rears, can run my konis on soft with a boot and bk full and get 0 rubbing at the bk , standard 30s on the front
