noise after boost??
Old 22-10-2005 | 08:52 PM
Hrsturbo's Avatar
Hrsturbo
Default noise after boost??
When I put my foot down, my car boosts up like normal then when I let off to change gear it makes a funny squeek noise like a shoe on marble floor if you drag your feet??
It squeeks for less than a second but its quite loud. Could this be the hoses??
They are standard hoses running 15psi and feel a bit soft but would this cause a squeek if they are fucked??
Also its losing boost in the higher rev range when its got a new -31 actuator on going to as low as 11psi sometimes??
Sound like fucked turbo, hoses or something else??
Any help appreciated thanks
Old 24-10-2005 | 09:38 PM
James Raby's Avatar
James Raby
Proably the turbo flutter as its known, can sound weird sometrimes lol
You won't hold boost on a MFi system, it's not made for it
Only advice I could give is get some silicone hoses anyway, for the price you can get them at it's worth every penny IMO
Old 24-10-2005 | 09:40 PM
mark-rst's Avatar
mark-rst
What do you mean by MFi can't hold boost?
Old 24-10-2005 | 09:43 PM
James Raby's Avatar
James Raby
Well, say you peak at 1.7bar, it certaily won't hold that all through rev range
You'd need some kind of boost controller
Old 24-10-2005 | 10:00 PM
mark-rst's Avatar
mark-rst
ah ok
timsrs
13-11-2018 11:48 AM
01-11-2015 06:53 PM
Mark RS
12-10-2015 06:01 AM
gingeRS
17
02-10-2015 09:42 AM
Russ Payne
25-09-2015 08:29 PM
Quick Reply: noise after boost??
