T28 on ERST?
Old 13-10-2005 | 10:09 AM
mantamark's Avatar
mantamark
Default T28 on ERST?
Any gains from fitting an escos T28 to an RS turbo?
Been offered a tubular manifold with T28 on it, full system with 5" pipe, probs change the pipe to a 3" outward rolled at some point.
Just wanted to know if it would be worthwhile fitting it?
Not clued up on the Ford range will start my research tho
Am also looking to get a chip & FMIC, its running 140bhp on std boost at mo, any ideas what i can be looking for once these changes are made?
many thanks.
Old 13-10-2005 | 11:47 AM
T28 RST's Avatar
T28 RST
Ok then
You got any pics of the tubular manifold
Old 13-10-2005 | 12:07 PM
mantamark's Avatar
mantamark
Whats your opinions?
Old 13-10-2005 | 12:28 PM
T28 RST's Avatar
T28 RST
Ok then
Ive seen 2 cars with set ups like this and both were from AVA, very good set up and both cars made very good power
Old 13-10-2005 | 12:31 PM
zippyobrien's Avatar
zippyobrien
looks like an awsome set up, does it move the turbo to behind the engine?
must be good for heat diplacement aswell!!!!!!
can you still buy this set up?
Old 13-10-2005 | 12:33 PM
mantamark's Avatar
mantamark
Yeh, the turbo goes behind the engine, and its an AVA setup
do you know what the rest of the spec was? just i dont know if i can just bolt this on & go, and i'm not sure where the pipework will have to run?
could do with a pic of the said setup?
thanks.
Old 13-10-2005 | 12:49 PM
Rick's Avatar
Rick
it'll be a very nice setup, good for well over 200hp.
T28 RST's Avatar
T28 RST
Ok then
The car made 220@ the wheels but ive heard it is a bit of a pain to fit, if you get it cheap go for it coz it works well
Old 13-10-2005 | 12:58 PM
mantamark's Avatar
mantamark
Pain in what way mate?
what else will i need to make the most of it?
my spec so far is....
Bailey evo dump valve.
Samco boost hoses, in red.
-31 actuator.
Magnex full exhaust, with 4" rolled tailpipe.
Boost gauge.
Drilled airbox, with K&N filter element.
Uprated clutch.
Uprated fuel pump.
Looking to get a nice FMIC & a chip soon too.
Just realised aswell, it comes with some pipework for the IC, but dont know if its for std or uprated
Old 13-10-2005 | 02:08 PM
mantamark's Avatar
mantamark
Have been told i may need a smaller housing like 0.49, but i was given no explanation as to why
any ideas?
Old 13-10-2005 | 11:02 PM
Rick's Avatar
Rick
no good one
Mc5506
05-10-2015 10:57 PM
beller
21-09-2015 05:13 AM
Ellsa
09-08-2015 08:03 PM
Dirty Harry
Trader Parts for Sale.
03-02-2004 07:39 PM
mot
17-01-2004 02:24 PM
Quick Reply: T28 on ERST?
