View Poll Results: dump valves, cool or not???
Voters: 125. You may not vote on this poll
Dump Valves, cool or not?
Heu Guys.
Got myself a series one RS Turbo. Its already fitted with a Bailey dump valve. Which I think is cool, but the lads in work think their sad.
What do you think???
cheeRS
Aubrey
cheeRS
Aubrey
i personally dont like them , having said that , some of the super cars , like for example the type you see on need for speed, do sound great , but i think they are not using a bailey one , i have the cossie management so i get a kinda chatter sound , even that bothers me .
my opinion???
take it off
my opinion???
take it off
If you have loads of boost (30psi) then it's required. But just having one for the noise is gayer than Christmas
An Escort RST will also have problems as they really don't like to run with a DV
i have an Forge DV on mine... i always liked the sound of a DV.. but i feel ya anyway.. overhere everybody is getting DV's on their cars.. But i like the attention when i come thru hahaha....
whats that with the engine not running right with a DV?? is there a technical explanation to it??
besides that... i heard a lotta people talkin about the turbo is damaged faster when ur not fitting a DV??
its not worth running on a car unless your running over 25psi boost and when i find rsts jerk when your comin on and off throttle and can be annoying
at the end of the day mate if you like it then have it
but if i was to have one id get one that doesnt go off until your on full boost coz theres nothing worse than one going off every time you let off. gets on my tits
i see someone around my area put 2 dumpvalves on his escort what the hells that for???
from what im told you can only get that chatter sound if your boost is very high... does'nt say nothing if you're running standard boost... !?
i ''think'' chatter is only on cars running efi, or cossie management , i have the chatter , and am running cossie management , but i dont like the noise either
Mine was on when i got her 11 months ago. Liked it at first but starting to get get a bit annoying now. Older people who don't know what they are turn round in the street and look at you when you come up behind them. They look at you like you are driving like maniac cos they can hear the noise, when in actual fact you are just driving like everyone else but just can't help the thing goin off ! Heard stories bout cars runnin crap when you take em off so leaving it on. Like it sometimes though when the right audience is lookin at the car ! ! !
As i said before... i always liked the sound of a DV... and i like the attention to it... everybody turning heads when you come thru with that sound.. and the airfilter is spitting and wheezing
but over here... a lot of people has begun to fit FAKE DV's on their cars without turbos.... thats some gay shit right there...
anyway... i think we have different opinions in Denmark and England.. seems like we do more for the attention than you do..
DANISH cosworth abuser
I like chatter better then the DV sound, but many people ar using them to get popular.... which they dont...
You should only put DV on if it is nessecery, on rs-t i would guess about 14psi an over...
Cosies have them standard, so they are escused
I have tryed 6 different on my car, but i use them to get performance AND protection to my engine/turbo....NOT sound
An Escort RST will get very minimal chatter unless it's been converted to EFi. The KE-Jetronic system does not like DV's as they introduce and air leak to the system that causes stalling, hesitation and other problems. You will do the turbo on these cars no damage at all by not having one and anybody telling you otherwise is a fool.
I have tried various different DV's and by far the best was to not bother so I don't have one at all and my Bailey twin piston valve is living in a box in the garage. The Escort runs at 25psi all day long and gets driven hard with no probs whatsoever.
The FRST has chatter and there is no way a DV will be going near it
I have tried with and with out a two piston dump valve, fully working and there was no difference in respons or anything else. You must have used a broken dump valve or a not suited one.
I have used three DV's on the car. A screw together diaphragm type a Bailey single piston and a Bailey twin piston. The twin piston was by far the best of the bunch but still had side effects so it was binned. I've owned my s2 for nearly a decade now and a lot of parts have come and gone as it's evolved.
Nothing to do with broken or unsuited valves, it's totally down to the way KE-Jetronic functions and it's inherrent inability to deal with air leaks in the system (which a DV creates).
i cant belive there at that many voters that think a dv is cool, but then i was driving an rs in 98 when dv`s 1st came on to the rs turbo scene
The difference must be in your head. I felt nothing when I compared with and without a twin piston dv on the same testing session. There is no airleak when the throttle is open. The pressure that builds up when closing the throttle will slam the sensor plate shut when running high boost. And we all know this metering head is sensetive and is the mother of most of RS Turbo running problems.
oranoco, i know what your saying, lol
along with a bleed valve ....hehe
no offence people, history repeats itself , ive just seen it happen
i have had that exact problem too oranoco , this is why i choose not to use a dv , owning such a nice car is enough for me , and already gets plenty of attention, and usually the wrong kind!!
I love the sound of chatter... if i didnt have efi i would consider a dv.. only prob is that it is a bit of a scally thing... although when i see them on nice s2 i think they can sound mint. So if your not a scall its okay.
Stall at lights and run rough? Sorry, never experienced that the two years I have had the car. A quality twin piston dv in good condition do not cause any running problems.
I think dump valves sound nice but the reason i havent got one is bcos i do loads of driving on motorways and A roads and what i experienced with the dump valve is that when you come on and off throttle the car seems to be jerky which annoys me but otherwise when driving around town it seem to be okay no stalling just normal but with the sound also you gotta make sure you have the twin piston one.
I ran a dumpvalve up until a months ago or so and there IS a difference in the way the car respondes! Its so much smoother on gear change ,no jerking ect
My s2 is running 12psi (159bhp) and i could hear chatter(Still running Mfi) over the DV so i took it off and it sounds so much better!
Before anyone says " Ya metering head is fooked!" ive had it checked out and its in perfect condition!!!
My advice to everyone is take off the gay dump valve unless its really needed or your that desperate for attention that you need it
Nick
Nick
I have one, the car boosts 25psi-I don't have it to get attention, the car runs perfect
Its down to choice at the end of the day, and it drills me when people call them gay-RS owners that run stock/low psi are fuckin gay
