windscreen washer motor/fuse
hi all, my escort windscreen washer is not working, i took my car 4 an mot this morning and it failed on welding and windscreen washer not working, witch fuse is it ? or is it a relay thats gone, i hade a quick look at the fuse but i dint see any that was blown, any ideas ? thanks.
By looking at a blade fuse as you have it's usually evident if it's blown by visual inspection but swap for another known fuse temporarily of the same rating to be certain. The contacts can cause problems in the fuse boxes with these older cars (Corrosion) Check you have +12V at one of the terminals WITH the ignition on, if thats good you need to be looking toward the motor itself, make sure the earth is good, I.E not corroded then I would put +12V directly to it, if it works then then it's a wiring/switch problem.
Martin
Martin
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
03-11-2015 04:08 PM
07-10-2015 12:56 PM
DavidK
27-09-2015 02:55 PM
